WTreeTable Events
ses
WTreeTable Events
Hi Experts,
I was able to show data populated in WTreeTable.
Now, I want to trigger an event when I click on the leaf node.
I want to call a service, with the leaf-node name as the parameter to the service.
Can anyone help in doing this?
5 REPLIES 5
ttielebein
(To:ses)
Hello, I am not sure what you mean by WTreeTable. Is this from an extension of some kind?
ses
(To:ttielebein)
Yes Tori. Itz a part of Windchill extension.
If my need can be served with TreeTable, then it is also fine if you put some guideline in it.
ttielebein
(To:ses)
Can you take a screenshot of where you are seeing this? I asked a member of the Windchill Connector team for guidance, and they still were not sure to what you are referring. Do you mean to say Tree Widget? That, I have heard of.
ses
(To:ttielebein)
I am referring to WTree Table.
Pls see the screenshot.
ttielebein
(To:ses)
So, I am not sure which extension includes this widget, but for the Tree Widget, in order to set up an event when a new leaf node is selected, you can try using the SelectionChanged event and tie that to a service of some kind. You'd have to bind an Infotable-providing service to the data on the table, and then bind a service to SelectionChanged on that service that as part of running would check to see if the selected item is a leaf node. If this doesn't work, then you will probably have to develop a customer widget. Documentation for that can be found in the Help Center.
Hope this helps!
Tori
