Is there a chart in thingworx like a waveform chart ? or maybe a way to configure one to have the X-axis always moving ?
I am also looking for the same chart!
Hi you can use the simple label chart as per your requirement you can use the Line/Marker type of chart you can plot
The problem with the LabelChart is that the X-axis as a timestamp is static, I want a dynamic Timestamp because for my project is not required to put all the historic data in a graphic but the recent ones.
Thank You
Hi
You can always have a timestamp on x-axis for label chart and its not static , you can see in picture where x-axis is binded as timestamp
a) you can bind x-axis field
b) Provide x-axis format YYYY-MM-DD (in this case )
c)select x-axis label type Date/Time
If you have data coming from multiple datasource you can uncheck SingleDataSource property of a chart and bind mutiple datasource having timestamp as
x-axis (dyanamic) , it will be easy .
If you have large dataset but from single datasource , i would recommend you to provide data filter widget or have a simple datetimepicker widget and configure it as To and From Date and show the results on chart
Thank You very much for your response,
I already have my X-axis format as a timestamp working, now I will try the datetimepicker widget
Hi
You may want to Refresh on select Intervals on your Time Selector widget.
