When would you choose one over the other? I can't find much documentation on the Connection Server.
Rob, an easy way to explain this would be - think of Connection Server as a load balancer. If you wanted to connect, say 1000 remote devices to the platform, which keeps taxing the platform with requests, connecting them to the platform via a Connection Server will ease the load.
The Edge MicroServer is a software/ tool which connects the remote device to the platform via WebSockets.
Hi Aanjan, Thanks for the reply. I have a follow up question. Does this imply that you would use both products in parallel then? Or does one replace the other.
They don't replace the other, as they are intended for two very different functions. You can use them in parallel though. The Edge Microserver pretty much opens a websocket connection from the remote device or the computer you are running it from, to the platform. You can send/ receive data both ways.
Sounds to me like you would need a Connection Server to manage multiple devices connected via one or more Edge MicroServer(s).
Device(s) ==> Edge MicroServer(s) ==> Connection Server (load balancing) ==> Thingworx (platform)
Would this be a valid configuration?
Yes, that would be a valid configuration. Again, a connection server would come into picture only when the volume or the number of devices is high.
On many implementations there are no connection servers needed because the number of assents is low <10.000 or the assets are not AlwaysOn and/or do not send large amount of data. Only if both conditions (many assets and much traffic) come into play there is need to start with connections servers to do load balancing.
Try without first.
Please remember to mark a response as correct if there are no further questions.
To mark answers correct is a super user function. This is nothing I can do. Maybe the question originator can mark it.
That's correct Stefan Bode, only the original poster, and site admins, have the the ability to "Mark As Correct".
That was directed at Rob Nalecz. Sorry Stefan for the confusion.
