When FileTransfer event from FileRepository thing has triggered?
and1
Have a problem with FileTransfer event. I wrote a subscription with code like this:
if(eventData.isComplete === true){
	me.IsComplete = "true";
And after I execute some of services, but don't have any result.
I'm confused about that, because i have no idea in which cases event has triggered.
1 ACCEPTED SOLUTION
PaiChung
22-Sapphire I
(To:and1)
You are subscribed to the FileTransfer event right?
You aren't even getting a FileTransfer start?
11 REPLIES 11
PaiChung
22-Sapphire I
(To:and1)
I would add some script log logger statements to see what is happening. especially I believe there is a status field you can log out?
and1
(To:PaiChung)
Are you mean a thing property?
PaiChung
22-Sapphire I
(To:and1)
Status should be in the event data or else associated with the transfer job.
and1
(To:PaiChung)
Oh, so just try to log result of status field for see what actually happened?
PaiChung
22-Sapphire I
(To:and1)
Right.
and1
(To:PaiChung)
actually nothing happened in script logs after adding logger.warn to my subscription
PaiChung
22-Sapphire I
(To:and1)
and1
(To:PaiChung)
Oh, I didn't understand right when the event is triggered
Thank you!
and1
(To:PaiChung)
So, this event triggered when we transfer our file from device(remote thing) to repository?
PaiChung
22-Sapphire I
(To:and1)
Correct, any copy event should trigger that event, Start, Fail, Finish
and1
(To:PaiChung)
Oh, okay, thank you.
