Where i can find thing, shape thing or Thing template built in related to machine learning?
mpagliotta
Where i can find things, shape things or Thing templates built in related to machine learning?
There only API's?
I do not find anywhere the workaround related to ML and thingworx composer.
Marco
What do you want to achieve?
i would like to create a pattern analysis related to some data industrial machine.
I would like  to clusterize  the behaviour of these machines and make some predictive anlaysis as try to predict when something goes wrong (turn off, errors...)
So i think i need some Machine learning object (thing?, shape thing, template things ? ) for create my personal things to modelise that.
If you need more infos let me know.
No suggestions?
If you have the ThingWorx Machine Learning Extension, you will have a "MachineLearningAll" template and "MachineLearningAllThing"
