Our Customer want to use Edge SDK in the Windows CE 6.0.
I don't know which edge sdk is compatible with the windows ce environment.
I would appreciate your answer.
Hi Kim,
I suggest to try with C/C# SDK.
As far as I know, VS 2010 and VS 2012 ,which are compilers of C/C# SDK, can be installed in Windows CE 6.0.
We don't have a Windows CE test environment to proof it, please try first and then deliver to your customer.
Lily
Yong,
Any update on this? Was Li Li Liu's post helpful? If so, could you click on the "correct answer" or "mark as helpful" button and let us know?
Hi Yong,
Any good news regarding agent running on Windows CE? I am facing the same challenge and I am wondering whether you manage to implement the agent?
Have the same question, don't know if c-sdk is compatible with win CE 6, can anyone give an example if a migration is needed?
The C SDK is compatible with Windows CE, but you will need to compile libeay32.dll and ssleay32.dll for the appropriate distribution for it to work.
Hi James,
Thanks for your sharing.
Lily
