Which Edge SDK is compatible with the Windows CE environment?
yonkim
Our Customer want to use Edge SDK in the Windows CE 6.0.
I don't know which edge sdk is compatible with the windows ce environment.
I would appreciate your answer.
6 REPLIES 6
liliu
(To:yonkim)
Hi Kim,
I suggest to try with C/C# SDK.
As far as I know, VS 2010 and VS 2012 ,which are compilers of C/C# SDK, can be installed in Windows CE 6.0.
We don't have a Windows CE test environment to proof it, please try first and then deliver to your customer.
Lily
jgorsline
(To:yonkim)
Yong,
Any update on this? Was Li Li Liu's post helpful? If so, could you click on the "correct answer" or "mark as helpful" button and let us know?
jacekgra
(To:yonkim)
Hi Yong,
Any good news regarding agent running on Windows CE? I am facing the same challenge and I am wondering whether you manage to implement the agent?
Have the same question, don't know if c-sdk is compatible with win CE 6, can anyone give an example if a migration is needed?
jamesm1
(To:yonkim)
The C SDK is compatible with Windows CE, but you will need to compile libeay32.dll and ssleay32.dll for the appropriate distribution for it to work.
liliu
(To:jamesm1)
Hi James,
Thanks for your sharing.
Lily
