Widget table with rows rearranging, using drag and drop
Sri1
For a project, on a mashup i wanted to perform sequencing of rows in a table by drag and drop method and submit it.
How do we achieve this on thingworx UI mashup programming.
I am uploading an image for example.
Some thing similar to this for a table.
Thanks and Regards,
Sri1
wposner-2
(To:Sri1)
Unfortunately, you're going to need to build a custom widget using a JS library that can enable the drag/drop functionality.
Sri1
(To:wposner-2)
Hi wposner-2,
How do i build the custom widget?
Do you have any sample that i can refer or use?
Thanks and regards,
sri1
Hello @Sri1 ,
As an alternative I would suggest using a pair of "Up" / "Down" buttons to the side of your list.
/ Constantine
bmihaiciuc
11-Garnet
(To:Sri1)
If you don't want to build out an extension for this yourself, you can try to install these two extensions:
And use the collection view widget (note: not the standard collection) which supports client-side sorting via drag & drop.
