Community email notifications are disrupted. While we are working to resolve, please check on your favorite boards regularly to keep up with your conversations and new topics.
Below is my code:
//creating an infotable
let Log = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape({
infoTableName: "InfoTable",
dataShapeName: "DataShape"
//Defining date variable
var currentDate;
//assigning valueList variable to my infoTable property that contains values (current it only has one row)
var valuesList = Things["TestThing1"].infoTableThingProperty;
//loop through the infotable above
for(var i=0; i<valuesList.length; i++){
// new object
newEntry = {
duration:valuesList[i].duration,
source: valuesList[i].Source,
Type: valuesList[i].Type,
StartTime: valuesList[i].StartTime,
EndTime: valuesList[i].faultEndTime,
Voltage: valuesList[i].Voltage,
Text: valuesList[i].Text
//adding my object values to the infotable
Log.AddRow(newEntry);
//adding my infotable to the stream
var newLog = Things["SinkWorx.PwrSupplyError_Stream"].AddStreamEntries({
values: Log /* INFOTABLE {"dataShape":"StreamEntryWithValues"} */
//output result
let result = Log;
I keep getting the error above, I am not sure why.
Does anyone know how I can fix it?
Kind Regards,
TB
duration: valuesList[i].duration,
Any o these INTEGER/NUMBER values might by NULL.
Try only with STRING values and change accordingly
try this..
let streamEntryData = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape({
dataShapeName: "StreamEntryWithValues"
var currentDate;
for (var i = 0; i < valuesList.length; i++) {
// new object
newEntry = {
// StreamEntryWithValues entry object
let streamEntry = {
sourceType: undefined,// STRING
values: Log,// INFOTABLE
source: undefined,// STRING
tags: undefined,// TAGS
timestamp: new Date()// DATETIME
streamEntryData.AddRow(newEntry);
values: streamEntryData /* INFOTABLE {"dataShape":"StreamEntryWithValues"} */
//output result
let result = streamEntryData;
Hi @Sathishkumar_C thank you for the suggestion but I am still getting the same error.
Hi, thank you for the suggestion.
I found that the error was with the subscriptions calling the service.
So I removed the infotable property that I was loping through and instead used the built-in service: "queryStreamEntriesWithData" and wrote an actual query which I then passed to this built-in service.
Also the subscription I added some conditional statements that need to pass before calling the service.
This solved the issue.
Best Regards,
TB
To narrow down the source of the error, put everything in a try-catch clause and log the error object with the line number.
try {
// Your whole code here
} catch(err) {
logger.error(err.message + " in line " + err.lineNumber);
