I used OPC DA Server to connect KEPWare to Thingworx, I can read Item values, and I can use KEPWare client to write item value,
but I can not write value to items in Thingworx even if I set item ReadOnly true.
"BaseType": "INTEGER",
"Name": "TemperatureUpperLimit",
"ReadOnly": false,
"Source": "Channel1.Device1.MyFBox.S7-1500.Item00.温度下限",
"SourceType": "System.UInt16"
