I'm using ROC Chard widget
it works fine, linking an infotable to "Data" and selecting the XAxisField and DataField 1..2....
However the XAsixField can be parametrized.
If i link XAsixField to a string (eg a textbox, just to try) giving the name of the field to use, the widget does not works.
I can make it running only if a select directly on the widget the infotable field use.
Has anyone used this XAsixField as a parameter ?
Is there a particular "syntax" for selecting the field name with XAsixField ?
probably it was installed by thingworx analytics (Analytics Builder)
I didn't take from marketplace.
This seems to be the only widget allowing a Line X-Y chart and possibility to dynamically customize the axis fields.
could you please share a screenshot from ThingWorx Composer --> Import/Export --> Extensions --> Manage
