Your route exchange has failed.HTTP operation failed with status [404 - Not Found]
BP_9517166
6-Contributor
I'm trying to connect SAP through thingworx SAPODATA Connector.
With the Demo gate way it's working fine. With SAP client environment Thingworx gives Error
Unable to Invoke Service GetEndpointList on VS.Test.SAPThing : Your route exchange has failed. HTTP operation failed with status [404 - Not Found].
here are the Generic Connector Connection Settings
  • Authentication Type = fixed
    • HTTP Connector Connection Settings
      • Username = <SAP Gateway user>
      • Password = < SAP Gateway pwd>
      • Base URL : https://sldev.slhana.com:9000
      • Relative URL : /sap/opu/odata/sap/ZCEP_DATA_SRV/ZCEPDATA
      • Connection URL : /opu/odata/sap/ZCEP_DATA_SRV/ZCEPDATA/$metadata
    • Validate service gives 503-Service Unavailable.
Please let me know my mistake.
Thank you in Advance.
Bhavya
1 ACCEPTED SOLUTION
@Ciprian-Traian ,
Thank you for the response.
yes, I'm connecting to external SAP network.
Issue is resolved there was a mistake in the base URL https://sldev.slhana.com:9000  /sap should be added at the end and relative URL should start from /opu/
Bhavya
Hello @BP_9517166,
Are you trying from your internal network to connect with an external SAP system ?
@Ciprian-Traian ,
Bhavya
