I keep receiving an error when I check the application monitoring page about an ado channel@thingworx.com not existing. How can I resolve this?
Most likely you have the XMPP extension installed and you have something created or in the model memory that depends on a Channel. Or something similar.
Pai,
Thank you for the response. I checked my extensions and I do not have the XMPP extension installed. Is there a way to search to find which thing or model is looking for the channel?
If you export it all, then you can do a search in the XML file for channel@thingworx.com
