change the system default timeout
nadams1
Is it possible to change the system default timeout? And where would you make that change?
it was the timeout mentioned in the settins for a property I was refering too. I manager o find it in the WSCommunictionsSubsystem
Thanks for your swift reply anyway.
jkaczynski
(To:nadams1)
By "Timeout" you mean "User Session Timeout" or "Agent connection timeout"?
If User Session Timeout -> please find a Subsystem "UserManagementSubsystem", then navigate to the Configuration panel. There you can configure Idle Session Timeout (min.).
