creating an XSLT file for XML File and Validating it
Irfan_Pasha
8-Gravel
Hi All, I've an Xml File created , I need to create an XSL File for this above xml file, And using this XSL File I need to validate the xml File, Please help me out.
slangley
(To:Irfan_Pasha)
Hi @Irfan_Pasha.
I'm still not understanding your use case as it relates to ThingWorx., but ThingWorx does not offer the ability to create a file in an Excel format.  You can write your own extension to provide the functionality you need.  Here are a couple of resources to help:
Create an Extension
Best Practices for Developing Applications
Regards.
--Sharon
slangley
(To:Irfan_Pasha)
Hi @Irfan_Pasha.
Please explain further regarding your use case.  Are you actually trying to create an Excel file from ThingWorx?  When you say you need to validate the xml file, what are you validating against?
Regards.
--Sharon
I've an xml file
and i need to create an XSL File for it
i need to transform the xml using this XSL File.
slangley
(To:Irfan_Pasha)
Hi @Irfan_Pasha.
Create an Extension
Regards.
--Sharon
slangley
(To:slangley)
Hi @Irfan_Pasha.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.  If you are still searching for answers, please provide further details and we will try to assist.
Regards.
--Sharon
