The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
My default user login is "Administrator". I want to create multiple user logins with different credentials(eg. User-Sheetal password-Sheetal@1234567). And how can i give permissions to access them.
I have created user, also organization and assigned user in organization. What should i do next?
How can i do it?
Sheetal Sable
Hi, the multi-user login creates different sessions, the permission for each login only depends on the User you used. So configure the User permissions carefully would grant them different access.
The Organization gives Users 2 rights:
1. Visibility permission to entities
2. FormLogin access to Home Mashup of the Organization.
Permissions in Thingworx fall into three categories
Design Time - What can you do with the model itself / Developers
Runtime - What can you do within the model / End users
Visiblity - What of the model can I work with
I highly recommend you take the courses that include security modules because it is very granular and specific.
also here is the help on it: http://support.ptc.com/help/thingworx_hc/thingworx_8_hc/en/index.html#page/ThingWorx%2FHelp%2FComposer%2FSecurity%2FSecurity.html
Hi @Sheetal_sable.
If one of the previous responses answered your question, please mark the appropriate one as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
