hi, i use widgets:DataGridWidget to show my table.
And i want to save table when modify data.
Is DataGridWidget has features of "selectionTable" ?
where can i find it ?
Or what should i do it ?
thank all
Hi Amelia,
You can use the Edited Table option in the Grid Widget as an input to an Add/Update service from DataTable you want to save the information on.
Cheers
Ewerton
Hi,Ewerton
Thanks for your reply.
But I want to emerge the result of tab.
As shown below
And the Grid Widget has no way to do this.
Does DataGridWidget has Edited Table option like Grid Widget ?
Amelia
Hi amelia shen,
Is Data grid a custom extension? From where did you get it?
I can't find it in ThingWorx composer nor on ThingWorx IOT Marketplace.
Ankit Gupta
Hi,Ankit,
Yes,it is a Data Grid extension.
But I find it only displays the effect of pages.
So , finally I use Grid Widget.
