For ThingWorx in windows, iam using Ctrl+Alt+F9 shortcut to debug mashup. But what is the shortcut to use debug for mashup in Linux, Ubuntu ??
Hello @AP_9587236 ,
Can you pls revert , how ar you accessing the ThingWorx URL in ubuntu or linux? As far as i know, if you have installed the desktop on ubuntu OS thn same shortcut will work.
Bhawna
While i cant find a keybord shourtcut for enabling debug for mashup in Linux i found a workaround.
Just add "&__fromNextGen" after name of mashup in the url.
For Example :
http://<host>:<port>/Thingworx/Runtime/index.html?mashup=<mashupName>&__fromNextGen
This will load the Mashup with top debug pane
