I am seeing this same behavior with the defaultMapicon on the google maps widget. I have created a new user group and added it to a global group and organization that has visibility and Run Time access to the Google Map Thing. I did not actually see a resolution even though it states it is solved.
My first thought would be to grant visibility rights to all Media Entities
also make sure that there are permissions to GetAllStyle/State/Theme definitions
Hi @TricoSupport,
Do you still need help? Or did @PaiChung provide the missing link/s? If he did, kindly mark the reply from @PaiChung as accepted solution, this will benefit other community users;o)
If you still need assistance then kindly provide more information to the post.
Thank you.
Asia
