fileRepository.LoadText topic
Gucio
hi,
After executing code:
var fileRepository = Things[fileRepository];
var fileContent = fileRepository.LoadText({ path: preparedFile });
file is "locked". I've even thought that there is something like close method (fileContent.close();) - but it's not :(
any idea how to unlock it??
thx
Krzysztof
1 ACCEPTED SOLUTION
raluca_edu
(To:Gucio)
What version are you using?
This issue was corrected in 8.3.0.
Please find related article here.
Best regards,
Raluca Edu
5 REPLIES 5
raluca_edu
(To:Gucio)
Best regards,
Raluca Edu
Gucio
(To:raluca_edu)
hi,
ThingWorx 8.1.3-b121
regards
Krzysztof
raluca_edu
(To:Gucio)
On versions before 8.3, this is reported as defect to R&D.
Unfortunately, I do not know any workaround for this issue.
If you have the possibility to upgrade/change version to 8.3 , then LoadText will not be an issue anymore.
Best regards,
Raluca Edu
Gucio
(To:raluca_edu)
thx for your response.
I use TXW with Navigate and Windchill - so before upgrading, I have to check compatibility table.
regards
Krzysztof
slangley
23-Emerald II
(To:Gucio)
Hi @Gucio.
If you are satisfied with Raluca's response, please mark it as the Accepted Solution for the benefit of others on the community.
Regards.
--Sharon
