I am passing configuration json to treegrid. For the html basetype columns, "overflow": "fitted" field is not working. so texts inside every cell of grid is not wrapping. How to fix this.
How to add wrapping in html basetype columns or css of grid?
Please download the XML file of " Grid Advanced Example Entities" from below link and import to your Thingworx instance.
Then find thing <GridAdvancedExampleServices>, check code of service <GetEmployeeRoleBasedConfiguration> and you can see below content.
Please modify your Json settings accordingly.
For more details, refer to below section.
