I have two mashups (gridMash & popupMash). In gridMash i have one grid widget which have 3 columns(key1,key2 and name) and two buttons ADD & EDIT.
in popupMash i have two list widgets as dropdown and two buttons(stack) ADD & EDIT. if i click on ADD i am adding new values in grid, if i click on EDIT then i am passing the selected row(grid) values to popupMash. i have created mashup parameters in popupMash. i have binded the key1 mashup parameter to selected text of list widget1 and key2 to listwidget2 selected text and i have also filled the valuefield. but i am not getting the selected text in list dropdown widget. can anyone help me where i am missing.
Did you try both Selected Text and Selected Value
Display field should be selected Text
Value field should be selected Value
Of course make sure you are firing off the service that populates the values into your dropdown.
Hi pchung,
Thanks for the reply.
I am getting the data for two dropdowns from two different services which results in an infotable with one column(key_name) each, I am binding the all data of each service to its corresponding dropdown data , assigning the display field to key_name. Now i'm binding values of "popupMash" mashup parameters key1 and key2 to selected text of two dropdowns , assigning the value field to key_name. after this changes also, i am unable to see the selected text in dropdowns.
I need some info: is there any property "selected value" for dropdown . I am using thingworx7.1.3 version. I can see only display field, value field and selected text properties.
Thank you.
