how to check if a remotething is bound
Below is a platform service that is called from an EMS to determine if a remotehing running
on a server is bound to the platform.  I used the Thing Service under TW Composer to help create
this code:
var params = {
    name: ThingName /* STRING */
// result: BOOLEAN
var result = Resources["EntityServices"].IsRemoteThingBound(params);
I pass in a thing string name(ThingName) and it returns result(a Boolean true/false).
This issue is that the result value is always true, even when the thing is not bound or if
the thing does not exist on the platform or within the EMS as a virtual thing.
Ideas on what I'm doing wrong?
Rick, you can check the isConnected property on the Remote Thing itself. It will be set to true only when the Remote Thing is connected.
