how to display the hierarchical data in form of tree in mashup
achitters
9-Granite
how to display the hierarchical data in form of tree in mashup as shown in the image.
3 REPLIES 3
supandey
(To:achitters)
Hi @achitters you can use Grid Advanced Widget from ThingWorx Marketplace. It contains both Grid&Tree widget allowing you to display such a hierarchy. Additionally there's a sample entity within the zip that you'll download named GridAdvancedExampleEntities-v3.0.xml this will create some demo mashups and things with services to return demo data something the attached screenshot
PaiChung
22-Sapphire I
(To:achitters)
Thingworx has a structure called Networks which creates that hierarchy and can be easily visualized in the Tree widget in a mashup.
What it depends on is a table that has to and from or child and parent relationships.
for example
child   |   parent
    A    |
    1    |      A
    2    |      A
    B    |
    3    |      B
    4    |      B
This would give you two root nodes called A and B each with two children
The only requirement to be able to use a Network is that they all have to be Things, if that is not needed, you can create a DataTable instead. Make sure you have the Child and Parent field as primary in the DataShape.
aanupeter
(To:PaiChung)
i am a beginner in thingworx. I would like to understand how we can bring the data into Tree widget. Could you please explain in more detail? It will help me a lot. Thanks for your understanding.
