how to display xml content ?
向郭
7-Bedrock
when test with getxml(), the thingworx output *XML*,how to display xml content?
5 REPLIES 5
supandey
(To:向郭)
Xiang, have you already tested with the ThingWorx Marketplace Extension called Universal Converter Extension ?
向郭
7-Bedrock
(To:supandey)
No,I don't know it's usage.
jamesm1
(To:向郭)
You can't display XML content in the composer. You can view it either by creating a mashup and binding the result to a widget such as the textbox, or via the rest API.
If you want to display XML content on the composer, set Result type to String, and do var result = ""+yourXMLObject;
aahmed1
(To:向郭)
if you want to test the service, just set the base type in "Inpu/output" to info table. From snippet call GetXML(), set the url in double quotes.
that should work
