how to get data from infotable ?
向郭
7-Bedrock
I want to get data from infotable ,for example , an infotable have two column and with lots of data, the columns are "date" and "temperature", I want to get the temperature in the time "2017-01-14 PM02:30:00"  ,then bind the data to one thing's property , what should i do ?
supandey
(To:向郭)
Hello Xiang,
I suppose you looking to filter the InfoTable, check the Find function for InfoTable it should allow you to get the row(s) as per your defined criteria
e.g.
var myFuzzyObj = new Object();
//defining the value against which I will run the Find function on InfoTable
myFuzzyObj.col1 =123;
myFuzzyObj.col2='StringValue';
//using Find function to look for the first row that matches my required criteria;
myFuzzyInfoTable.Find(myFuzzyObj);
Of course there are bunch of other Filter options that you can apply to your InfoTable, try this Getting to Know InfoTables.pdf
Hope this helps.
