Hi i'm SeonHo
i want to hide tooltip under radio-button
how can i hide that?
i use TWX 7.3
Hi SeonHo,
The position of a tooltip cannot be customized however if you are looking to remove the tooltip for a widget , just remove the text from the ToolTipField in the widget properties.
Here is a useful link on tooltips from the help center : Digital Media Publisher
Hi SeonHo,
Thanks i set state string field and tooltip hide
