how to read an infotable having integer value
MA8731174
Hello Community,
I am getting the data in an infotable but i am unable to read it.
const SERVICENAME = "getPieChartDataOnMashup";
logger.info(me.name + " :: " + SERVICENAME + " :: Start Service");
let projectName = me.name.match(/^[^.]*/)[0];
let ab;
try {
     ab = Things["V2.MYSQLDatabaseController"].SQLQuery_GetEntriesForPieChart({
        lineName: lineName,
        StartDate:startDate,
        EndDate:endDate
    logger.info(ab.rows[0]);
} catch (e) {
    logger.error("There is an error in service getPieChartDataOnMashup DataBase service.SQLQuery_GetEntriesForPieChart " + e);
 let result = ab;
the below pic is for logger ab.rows[0]
the below is the output of the service. i am unable to read in logger ioEntries like ab.rows[0].ioEntries the values is 0 but i am getting undefined. Why? i am getting this data from SQL query and i have set the ouput as an infotable with two fields of number.
Hi @ZbigniewK  and @Arun_C
Thanks both of you for your insights. Its actually spelling mistake and sometime thingworx needs to be refresh the service inorder to see effects but yeah its working now. Below is my code also. May be it will be useful for other people.
let AnalysisInfotable = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape({
    infoTableName: "InfoTable",
    dataShapeName: "V2.Analysis.DS"
let queryresults;
try {
     queryresults = Things["V2.MYSQLDatabaseController"].SQLQuery_GetEntriesForPieChart({
        lineName: lineName,
        EndDate:endDate
//    AnalysisInfotable.AddRow({Label:"ioEntries",Value:queryresults.rows[0].iOEntries});
//    AnalysisInfotable.AddRow({Label:"nioEntries",Value:queryresults.rows[0].niOEntries});
        AnalysisInfotable.AddRow({Label:"ioEntries",Value:50});
    AnalysisInfotable.AddRow({Label:"nioEntries",Value:60});
    logger.info(queryresults.rows[0].iOEntries);
} catch (e) {
 let result = AnalysisInfotable;
Do you guys know that how can i make infotable to show more then 500 rows. I am getting data from SQL query and its more then 500 but as the infotable only shows 500 rows. any idea how can i fetch more then 500? For datatable i know how to make it work with maxItems but i am not sure about infotable.
looks like spelling mistake, but you in logs you have iOEntries (low I, O in capital, E in capital, rest of text in low), but then you write ioEntries (O in low, not in capital).
Of course, if it's only mistake in your post, then do not care about my answer, but if it is also in your code - then I hope I helped you. Sometimes it's most difficult to notice such a small mistypes
Hi @MA8731174 ,
Try to log the complete infotable in the logger like below code
logger.info(ab.ToJSON());
Else you need to log only 1 column values means please find code.
logger.info("Log Message Of First ioEntry Value: " + ab.rows[0].ioEntries);
Thanks & Regards,
Arun C
let queryresults;
try {
        lineName: lineName,
        EndDate:endDate
} catch (e) {
Hi @MA8731174 ,
Kindly increase the Max rows from Database Thing - SQL query service. If you need to all rows make it with -1. It will works.
Kindly find the attached link - https://www.ptc.com/en/support/article/CS332284
Thanks & Regards,
Arun C
