how to reload a page from a popup
AP_9587236
On clicking "Apply" button in this popup, i want to reload the main mashup. On clicking a button, one service will be called. I binded that service serviceInvokeCompleted to an expression which having a code "location.reload();". But the page is not refreshing. How to do this.
6 REPLIES 6
PaiChung
22-Sapphire I
(To:AP_9587236)
From what you have listed, you have all the steps.
Is the expression not firing? Is your 'location.reload()' in the pop-up or the parent mashup?
If it is in the pop-up, I don't think it will work. If you don't need the pop-up after refresh, you can do it using 'pop-up close'
Also do you need a full refresh vs. just a 'data reload' which would mean just re-triggering services that populate the data on the mashup.
I have given location.reload(); inside popup. It reloaded the parent mashup also only when "Apply" button clicked for double times. But i want it to happen on single click itself.
PaiChung
22-Sapphire I
(To:AP_9587236)
If it isn't doing it on the first click but only the second, perhaps check your expression and troubleshoot if it is firing properly or not?
I gave "Fire on First Value", it is working now. Thanks
May be you can define and change a session param value with a random number / datetime from popup and on this session variable change you could reload the parent mashup
ill Try this.
