how to set rows with custom order in dropdown Thingworx 9.1.1
  • August 4, 2021
  • 1254 views
Hi ,
I have Datatable which contains 20 rows and i have written service which fetch Machine names from this Datatable and displays in Dropdown , but i want order of rows same which is in Datatable. how to achieve this. if we manage it at dropdown also No issue.
Vaibhav
Best answer by PaiChung
If you need to enforce an order, I recommend you add an order field to your DataTable (assuming there is no suitable field to order on available) and then apply sort to that order field.
22-Sapphire I
August 4, 2021
In your service that fetches the data, apply a Sort
Hi @PaiChung ,
If we sort in Service, it will return either Ascending or Descending. I want custom order that is how I have inserted in Datatable
in same order dropdown list should hold. If you elaborate more on this , would be better.
PaiChung22-Sapphire IAnswer
22-Sapphire I
August 5, 2021
