i created a widget with a xml file and import into thingworx ,but always with the error message"Extension must have a metadata.xml file."
the content of the xml is
and my widget file list is
so what is the reasong i failed to import this widget to thingworx
your extension package should contain a folder named ui and metadata.xml.
dear Meenakshi ,thanks for your answer ,i have solved this problem by another compressed software ,but after i import my widget into thingworx ,the other widget like googlemap, customchart i imported are not in the list ,i don't know the reason
