I am developing a service in a thing that sends data to a 3rd Party rest endpoint through https. And I get this error:
Wrapped java.net.SocketException: Connection reset Cause: Connection reset
Here's the javascript for the service below:
var url = "https://{url} /{endpoint}";
var content = {
on: true
var header = {
Authorization: "Token {key}"
var params = {
headers: header /* JSON */,
url: url /* STRING */,
ignoreSSLErrors: true,
content: content, /* JSON */
var result = Resources["ContentLoaderFunctions"].GetJSON(params);
Any ideas to how this can be solved is appreciated. Is it possible that Thingworx is ignoring the ignoreSSLErrors flag? Thanks.
The error appears to be higher level then just a generic SSL error.
The connection is terminated, depending on how it's implemented you could try and catch the exception yourself and discard it, you'd have to check explicitly for this exception though if you want to do this, otherwise other exceptions are discarded also.
Is the data successfully send though?
Pascal
Hi @pmessina
Hope you are doing good. Could you please confirm if the issue has been resolved.
If yes, please mark the answer as accept as solution for the future reference. Thank you in advance.
Regards-Mohit Goel
