I has just imported the .json file to the new instance machine.
The file is about 2Gigabyte and it just takes a long time to import.
After few minutes, tomcat crashed.
Is there any solution about this problem?
How can I import such a large .json file to another machine?
Thanks!
Wanting Deng
If tomcat crashed, I think tomcat is allowed to use more memory than the machine's RAM.
Are you using Neo4j or Postgre ? There are some configurations about waiting time, max size... It's sure that importing a 2Gb file will take a long time.
Dear QD N sir,
Sorry for the delay in getting back to you.
As you said, I set too much memory to tomcat.
Now, it seems okay now.
And I'm using Neo4j as my database.
If there is any problem, I will appreciate that you are able to support me.
Many thanks!
Wanting Deng
