Aug 23, 2019 7:14 PM UTC
keytool error: java.lang.Exception: Input not an X.509 certificate
I am following the instructions here:
https://developer.thingworx.com/en/resources/guides/foundation-linux-install-guide/foundation-linux-create-ssl
Using JDK 1.8_131and Ubuntu 18.04 LTS
I keep getting the error above.  I found this article, https://www.ptc.com/en/support/article?n=CS147810, but it requires a maintenance subscription.
18-Opal
Aug 28, 2019 7:05 AM UTC
The second version is correct. Since you are on Linux, it backslashes are interpreted as escape sequences instead of path delimiters, so the filename becomes incorrect and keytool cannot find it, giving this cryptic error message.
Then, keytool -import asks you for the destination store password, which is cacerts in this case, which is part of the JRE. The default password is changeit, please try it.
Finally, try to export your certificate from the JKS first, i.e.:
keytool -export -alias tomcat9 -file certificate -keystore twkeystore.jks
...and use "certificate" as the filename for keytool -import.
/ Constantine
18-Opal
Aug 26, 2019 10:16 AM UTC
Can you provide the exact commands that you execute? Also make sure you execute it from JDK's bin directory. Ah, and you should probably replace the backslashes with the forward ones...
Constantine
Aug 27, 2019 8:03 PM UTC
With \ slashes
root@thingworx-test:/usr/lib/jvm/jdk1.8.0_131/bin# keytool -import -alias tomcat9 -file "twkeystore.jks" -keystore "..\jre\lib\security\cacerts"
Enter keystore password:
Re-enter new password:
With / slashes
root@thingworx-test:/usr/lib/jvm/jdk1.8.0_131/bin# keytool -import -alias tomcat9 -file "twkeystore.jks" -keystore "../jre/lib/security/cacerts"
keytool error: java.io.IOException: Keystore was tampered with, or password was incorrect
I looked at the CA certs using the help on digi and think java is right and the cacerts file is not an X.509 cert.
18-Opal
/ Constantine
