Hi all,
Have you experienced about machine learning in the Thingworx platform.
Which database is available? Internal or external? (for big data)
Any default algorithm is developed in the platform ?
We want to use the machine learning analysing for collected big data
Could you share the your suggestion please.
We didn't found more info about this topic
Thx
Hi
You could look at ThingWorx Analytics which perform machine learning operation.
See this Getting started article for high level overview
See also the QuickStart Guide
Hope this helps
Christophe
Hi
Hope this helps
Christophe
