mashup not running
dmahoney
mashup not running
I'm running Thingworx 7.2.
I created a Mashup that contains two other mashups.
If I run the Mashup as an Administrator, the containing mashups execute and load appropriate data.
If I run the Mashup as a non-Adminstrator, the containing mashups don't execute and do not load appropriate data. There is no application log information indicating any problems.
Dan
posipova
20-Turquoise
(To:dmahoney)
Do you have the non-administrator users in "Everyone" organization?
I did not. I added them.
Same problem still exists.
Dan
posipova
20-Turquoise
(To:dmahoney)
Have you tried different browsers?
Could you please check your browser developer tools, see for any suspicious activity/errors during the requests in there?
It does sound like some permission issue though. I'm assuming once you add a user to the administrator group, it shows properly. Is this a problem with any contained mashup or just some particular one?
