I'm using ThingWorx 8.2 and in a meshup I defined a textarea that should use monospace font (ie: Courier).
So in "New Composer" I set textarea's CustomClass=abFont and in Custom CSS I defined:
.abFont {
font-family: Courier !important;
However when I save and preview the meshup I see that abFont is applied to the outer bounding-box.
The font information is however overrided between such outer bounding-box and the inner textarea where the font is supposed to be monospaced...
How can I fix this ?
Thank you,
A.
Thanks for including the page source with your question, that really helps.
Have you seen this guide to CSS:Style UI with CSS>Apply Custom Class to Widget
I think you need to add
.widget-textarea textarea
to your class, making your class look like this
.abFont .widget-textarea textarea { font-family: Courier; }
I don't think the !important does anything
Hello alsmith,
what you say does really make sense and even more important.. it works!
Thank you so much,
Andrea
