I am using the TextAtea widget to create am Info-popup to provide explanations about the mashup.
However I cannot write a new line adding text directly into the Property Tab. I attach the result I obtain doing a copy/paste from Word.
Do you have any solution for that?
kind regards,
marco
Hello darcudarcu,
Thank you for reaching out on the ThingWorx Developer Community.
My recommendation in this instance is to utilize multiple Label Widgets (one for each bullet point). The TextArea Widget you are currently utilizing is mainly designed for long-text inputs at run time whereas the Label Widget is intended for text display at runtime.
Hopefully this helps.
Tyler Misner
ThingWorx Technical Support Engineer
Hello darcudarcu,
Tyler Misner
