I have two TW setups on different machines.
When i exported entities from one TW environment(which is on a VM) and imported to another TW environment(my local setup) the entities got imported successfully. However, none of the property values are reflecting for any of the entities.
I have marked these property values as persistent and these entities have been created by making REST api calls.
Please help.
What is your ThingWorx version? What is your backend database, PostgreSQL?
What type of entities were those?
Could you please supply the applicationlog.log to check for any obvious errors?
