Hi, Is it possible to print only the grid rows in ThingWorx? On click of button, the dialog should open the print screen which has only the grid. How can I achieve this?
Thanks in advance,
Shalini V.
There isn't anything OOTB that can do this.
You can use the export to CSV (data export) widget and then do the print.
Or you can create a custom extension perhaps to accomplish this.
If you feel your question has been answered, please mark the previous response as the Accepted Solution for the benefit of others with the same question.
--Sharon
