Hello i'm SeonHo
The question is how to configure in the mqtt extension
This is an automatic format for subscribing, so it subscribes automatically.
If so, is there a format for automatic publish?
For subscriptions, you can access each Thing using format[ Thingworx / {t} / temp].
So I thought publish could automatically deliver the value to the matched device.
However, the settings for publish must be made by the developer within Thingworx Composer
I want users to publish conveniently
For example, a Thing is created with the name of the device registered by the user, and the generated Thing receives the value of the device registered in Thingworx / {t} / temp
However, in order to publish, you have to add or update the configuration in Composer.
I want to publish as a subscription and automatically set up a topic as a matched device.
Any suggestions?
