Hi, I am trying to create a digital twin for inspection and save information from it, like pass or fail, why was it failed, etc. But I'm not sure how to go about it. I have created a DataTable in Thingworx Composer but not sure how to record the data from the digital twin. Any suggestions or ideas would be greatly appreciated.
Hello, Lipi.
I think we need some more information about your use case to make a good recommendation for you. Your digital twin is not a connected Edge device; is that correct?
-- Craig A.
EDIT:
Yes, that is correct. Digital twin is not connected to Edge device. It has sequence created in Creo Illustrate that shows steps for inspection.
After each Step, a voice command will take it to the next step. I would like to incorporate voice-commands/gestures to pass or fail the inspection at every step. If the inspection fails, I would like to be able to record the reason for failure by selecting from a drop down menu. I was wondering if it is possible to save the pass/fail and reason for failure in a spreadsheet or pdf format. If yes, how can it be done?
Lipi.
