I'm writing a Database connection thing to insert data into my local database. I have a service type of SQL(command) accepting type INFOTABLE parameter. But Thingworx complains when using fields of this parameter:
Error executing SQL command. ERROR: ERROR ERROR: syntax error at or near "["; Error while executing the query
The way I'm inserting the record is like this:
insert into myTable values ([[myInfotable.recordOne]], [[myInfotable.recordTwo]]);
When breaking the INFOTABLE into a list of parameters, this way of insertion works just fine.
Can you guys help? Thanks a lot.
Can you try this using << >> vs. [[ ]] that does mean it becomes String substitution vs. parameter substitution and you have to be aware of possible SQL injection.
Thanks for your reply, I tried the <<>> method, but still get errors.
I guess SQL Command services cannot access infotable fields inside right now, is that right?
That is probably the case, you can still use the second method that I proposed.
At least with Postgress <<>>works. I am able to pass query/insert using parameters which I received as input from service. More detailed documentation around this will be nice since each database may be treating things differently.
Varathan
Can u write down the service of command please? i don't konw how to use the <<>> in the postgreSQL
Excuse me,have you solved the problem? I had the same problem~
I'm having the same problem as well, but with ORACLE. Parameters such as [[infotable.value]] are returning ORA-00936: missing expression. <<infotable.value>> is returning the same.
