Hi All
Once again, there is probably a simple solution to this that I am missing.
I have written some code that outputs to an infotable, with a column being day. I use the infotable to populate a bar graph. I am looking to change the day column to display the actual day of the week instead of 0 - 6.
if (buckets[eventDay] == null) {
buckets[eventDay] = new Object();
buckets[eventDay].Date = eventDay;
buckets[eventDay].Day = eventDay.getDay();
buckets[eventDay].Min = 9999999;
buckets[eventDay].Max = -1;
var bucket = buckets[eventDay];
if(eventAmount > bucket.Max) {
bucket.Max = eventAmount;
if(eventAmount < bucket.Min) {
bucket.Min = eventAmount;
// logger.warn("eventDay (" + eventDay + ") bucket max (" +bucket.Max+ ") bucket min (" +bucket.Min+ ")");
bucket.Usage = bucket.Max - bucket.Min;
var params = {
infoTableName : "InfoTable",
dataShapeName : "eventAmountDS"
// CreateInfoTableFromDataShape(infoTableName:STRING("InfoTable"), dataShapeName:STRING):INFOTABLE(eventAmountDS)
var result = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
var bucketIndex;
for(bucketIndex in buckets) {
// logger.warn("bucketIndex (" + bucketIndex + ") bucket (" + buckets[bucketIndex] + ")");
// logger.warn("min (" + buckets[bucketIndex].Min + ")");
// logger.warn("max (" + buckets[bucketIndex].Max + ")");
result.AddRow(buckets[bucketIndex]);
Add a Select statement to take 0-6 and convert that to Sun-Sat?
