Use a Validator widget, create an input for it and check with expression input=false, then bind the Boolean output of the widget to Disabled input of the Button widget
Is there any place I can read about validator in detail. my scenario is to read a property from a thing and validate it using the validator
Hi @zyuan1 I am able to execute the validator but it only works once when i click one button it disables the other but for some reason it does not refresh back when I hit the second button
In your question description you just mentioned one button controlled by service result, what's your second button here for?
You can change the Validator expression to follow your business logic.
@zyuan1 I have two buttons which are start and stop I just want the functionality in such a way where when one starts the system and other stops it when I applied 2 validators which read the property and validate the states of these buttons the issue, however, is this process is only happening once even when I checked the auto evaluate property of the mashup I'm unable to work it out
When the decision process is complex, you could draw a work flow chart including [input value] [expression] [trigger event] [result] to check why it failed.
Another way around, since you need 2 buttons, you could also try the CheckBox widget (Boolean) or RadioButton widget (state definition with 2 String type, OPEN / CLOSE). Carefully design the validator expression and it could be easier than using 2 Buttons.
Hi @mahitejg.
If you have found a solution to your problem, please post it here or mark one of the existing replies as the Accepted Solution for the benefit of others with similar issues.
Regards.
--Sharon
