I have an error while installing.tried to adjust the cpu and memory, the error is still. Unable to install. Please help
Please see attachment for errors.
System environment:windows 7 x64 Professional version
Hardware Configuration:disk 160G ,RAM 32G ,cpu e5-2630 * 8
docker info:
$ docker info Containers: 1 Running: 0 Paused: 0 Stopped: 1 Images: 1 Server Version: 18.05.0-ce Storage Driver: aufs Root Dir: /mnt/sda1/var/lib/docker/aufs Backing Filesystem: extfs Dirs: 3 Dirperm1 Supported: true Logging Driver: json-file Cgroup Driver: cgroupfs Plugins: Volume: local Network: bridge host macvlan null overlay Log: awslogs fluentd gcplogs gelf journald json-file logentries splunk syslog Swarm: inactive Runtimes: runc Default Runtime: runc Init Binary: docker-init containerd version: 773c489c9c1b21a6d78b5c538cd395416ec50f88 runc version: 4fc53a81fb7c994640722ac585fa9ca548971871 init version: 949e6fa Security Options: seccomp Profile: default Kernel Version: 4.9.93-boot2docker Operating System: Boot2Docker 18.05.0-ce (TCL 8.2.1); HEAD : b5d6989 - Thu May 10 16:35:28 UTC 2018 OSType: linux Architecture: x86_64 CPUs: 4 Total Memory: 15.65GiB Name: default ID: OBYT:UWQZ:OIMK:4L37:4VPO:5ROS:4GQ5:ZXKP:GHY3:7FYG:E6TQ:4HIT Docker Root Dir: /mnt/sda1/var/lib/docker Debug Mode (client): false Debug Mode (server): false Registry: https://index.docker.io/v1/ Labels: provider=virtualbox Experimental: false Insecure Registries: 127.0.0.0/8 Live Restore Enabled: false
