I am able to retrieve the following XML from a web service and assign it to a variable, returnXML. However, I can't figure out how to retrieve the data elements within it. I've tried returnXML.customerProfileID, returnXML.messages.resultCode, etc but they values come back empty.
<createCustomerProfileResponse
xmlns="AnetApi/xml/v1/schema/AnetApiSchema.xsd"
xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<messages>
<resultCode>Ok</resultCode>
<message>
<code>I00001</code>
<text>Successful.</text>
</message>
</messages>
<customerProfileId>29734345</customerProfileId>
<customerPaymentProfileIdList/>
<customerShippingAddressIdList/>
<validationDirectResponseList/>
</createCustomerProfileResponse>
Thanks. I'll give that a try. Can you give me an example of doing it the 'long' way?
Take a look under Support/Examples parsing Soap/XML with Name spaces.
Thanks for the quick response Pai. That did the trick.
