I implemented a version of the Groovy script shown on the MobileLocation API Reference page as a Custom Object on the Axeda Platform. I get the following exception when I run this script:
Access to property DEFAULT_END_TIMESTAMP of class com.axeda.drm.services.mobilelocation.MobileLocationImpl not allowed
What is the proper reference to the DEFAULT_END_TIMESTAMP property?
It appears that a workaround is available for this issue. You don't need "lake" access if you know that DEFAULT_END_TIMESTAMP = 4136677158944L.
That API is located in the 6.8 Code Access Policy (CAP) level "lake." By default all new instances in the On-Demand Center are provisioned in "pond." "Lake" and "Sea" are progressively more permissive depending on your application requirements.
I recommend opening a support case to have your CAP level altered to lake.
-Chris Kaminski
PTC Customer Support
I almost posted that very answer - for while this is true, I'm always leery of recommending someone rely on implementation details like this.
-Chris Kaminski
I agree. How about making a constant like this, one that may be needed for correct script implementation, "public"?
I think the fact that it is not is an oversight, not intentional. Appreciate you bringing it to our attention John.
As noted earlier that feature is allowed in code access policy level "lake", which your instance can be adjusted to with a support case. So it is public, but I believe that this belongs in level "pond", the default. I've already started a process internally to review why this particular restriction is in place.
-Chris Kaminski
Chris, is this another example of the same issue? If so, how to I work around it?
Access to property STRING of class com.axeda.drm.services.device.DataItemType not allowed
at com.axeda.groovy.sandbox.access.v1.CodeAccessPolicyImpl.accessViolation(CodeAccessPolicyImpl.java:506)
at com.axeda.groovy.sandbox.SandboxControllerImpl.accessViolation(SandboxControllerImpl.java:225)
at com.axeda.groovy.sandbox.SandboxControllerImpl.isPropertyAccessAllowedFast(SandboxControllerImpl.java:162)
at com.axeda.groovy.sandbox.GroovySandboxController$isPropertyAccessAllowedFast.call(Unknown Source)
at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCall(CallSiteArray.java:42)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:108)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:128)
at com.axeda.drm.services.customobject.groovy$_run_closure1_closure2.doCall(com.axeda.drm.services.customobject.groovy.GroovyAction:97)
com.axeda.drm.services.device.DataItemType is also located in "lake".
I'll PM you directly, we can address this for you.
-Chris Kaminski
