unable to access DEFAULT_END_TIMESTAMP
ptc-4668818
I implemented a version of the Groovy script shown on the MobileLocation API Reference page as a Custom Object on the Axeda Platform.  I get the following exception when I run this script:
Access to property DEFAULT_END_TIMESTAMP of class com.axeda.drm.services.mobilelocation.MobileLocationImpl not allowed
What is the proper reference to the DEFAULT_END_TIMESTAMP property?
It appears that a workaround is available for this issue.  You don't need "lake" access if you know that DEFAULT_END_TIMESTAMP = 4136677158944L.
8 REPLIES 8
ckaminski
(To:ptc-4668818)
That API is located in the 6.8 Code Access Policy (CAP) level "lake."  By default all new instances in the On-Demand Center are provisioned in "pond."  "Lake" and "Sea" are progressively more permissive depending on your application requirements.
I recommend opening a support case to have your CAP level altered to lake.
-Chris Kaminski
PTC Customer Support
ckaminski
(To:ptc-4668818)
I almost posted that very answer - for while this is true, I'm always leery of recommending someone rely on implementation details like this.
-Chris Kaminski
I agree.  How about making a constant like this, one that may be needed for correct script implementation, "public"?
I think the fact that it is not is an oversight, not intentional.  Appreciate you bringing it to our attention John.
ckaminski
(To:ptc-4668818)
As noted earlier that feature is allowed in code access policy level "lake", which your instance can be adjusted to with a support case.  So it is public, but I believe that this belongs in level "pond", the default.   I've already started a process internally to review why this particular restriction is in place.
-Chris Kaminski
Chris, is this another example of the same issue?  If so, how to I work around it?
Access to property STRING of class com.axeda.drm.services.device.DataItemType not allowed
at com.axeda.groovy.sandbox.access.v1.CodeAccessPolicyImpl.accessViolation(CodeAccessPolicyImpl.java:506)
at com.axeda.groovy.sandbox.SandboxControllerImpl.accessViolation(SandboxControllerImpl.java:225)
at com.axeda.groovy.sandbox.SandboxControllerImpl.isPropertyAccessAllowedFast(SandboxControllerImpl.java:162)
at com.axeda.groovy.sandbox.GroovySandboxController$isPropertyAccessAllowedFast.call(Unknown Source)
at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCall(CallSiteArray.java:42)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:108)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:128)
at com.axeda.drm.services.customobject.groovy$_run_closure1_closure2.doCall(com.axeda.drm.services.customobject.groovy.GroovyAction:97)
ckaminski
(To:ptc-4668818)
com.axeda.drm.services.device.DataItemType is also located in "lake".
I'll PM you directly, we can address this for you.
-Chris Kaminski
