I was trying to give user permission for visibility and design/run time for style definition as well which is being used in mashups(for mashups permission is already set for that user and it's viewed perfectly well), also after removing the styles and replying it again, is not giving the correct result...plz suggest if you faced similar thing.
Abhishek Kumar
After setting the permission to platform subsystems, the issue got resolved... :)
